78dattysun Posted August 22, 2011 Report Share Posted August 22, 2011 Whats some good bucket or bench seats that you can grab out of another car that look good and bolt up half way easy and nice w/o cutting something out of your truck. even drilling new holes is fine. thanks Quote Link to comment
dat620 Posted August 22, 2011 Report Share Posted August 22, 2011 i have used 92-95 civic seats, they are a real easy mod, also 91-92 integra seats, also real simple mod, and you could always use datsun king kab bucket seats, they are a direct bolt in, try these and see how they work, i have seen some peeps use the hard body bench seat, not sure of how well they fit or if to wide, just seen them done before.. Quote Link to comment
rockstar 620 Posted August 22, 2011 Report Share Posted August 22, 2011 miata seats are simple to mount too..i have some for my 620 and they have the speaker pocket on the headrest so its cool theyre also small so they go with the truck.. Quote Link to comment
herculesinwyoming Posted August 22, 2011 Report Share Posted August 22, 2011 what about 720 bucket seats the 620 and 720 share floor pans and rocker panels Quote Link to comment
DAT510 Posted August 22, 2011 Report Share Posted August 22, 2011 what i did with prelude seats (i think) was drill out those weird mounts, then welded a piece of metal and drilled a hole into the metal and welded a bolt in there. super comfortable. Quote Link to comment
Radiant-Designer Posted August 22, 2011 Report Share Posted August 22, 2011 They are a little more expensive but I used Corbeau seats, they have mounting brackets for almost any car. If youre lucky you can find them on ebay or craigslist, i found 1 set at the bone yard, super lucky there :-) Quote Link to comment
