lil89ram50 Posted August 7, 2011 Report Share Posted August 7, 2011 well i just got my weber bolted down and ready to start, first of all, i need a manual choke, this one is electric. can i convert it with a kit? got a link to a good complete kit? second concern, it leaks fuel bad! its leaking out of the power valve. even when you barely touch the pedal, it POURS! this truck runs much better now, but it still leeds this horible leak fixed, and i cannot hold the butterfly's closed by hand every time i start the vehicle cuz i have no choke Quote Link to comment
610racecar Posted August 7, 2011 Report Share Posted August 7, 2011 well i just got my weber bolted down and ready to start, first of all, i need a manual choke, this one is electric. can i convert it with a kit? got a link to a good complete kit? second concern, it leaks fuel bad! its leaking out of the power valve. even when you barely touch the pedal, it POURS! this truck runs much better now, but it still leeds this horible leak fixed, and i cannot hold the butterfly's closed by hand every time i start the vehicle cuz i have no choke Since the power valve is located at the bottom of the float bowl, how do you know it is leaking there? It is a tough spot to see. Is your carb off the car? If so, take the top cover off and put fuel in the bowl to verify it is leaking by the power valve. This diagram may help you describe more accurately where it is leaking http://www.carburetion.com/diags/3236DGVDiaginfo.asp Marc in Indy Datsun 610 Racecar Quote Link to comment
lil89ram50 Posted August 7, 2011 Author Report Share Posted August 7, 2011 sorry, its leaking at the accelorator pump Quote Link to comment
jefe de jefes Posted August 7, 2011 Report Share Posted August 7, 2011 Its leaking?? :/ That's not good. I have one if you can wait for Monday shipping. http://www.joetlc.com/manual-choke-conversion-weber-carb-dges-dgev-3236-38mm-p-3056.html Quote Link to comment
lil89ram50 Posted August 7, 2011 Author Report Share Posted August 7, 2011 do you guys think its the diaphragm inside? Quote Link to comment
Sealik Posted August 7, 2011 Report Share Posted August 7, 2011 You lost me....you want a manual choke...but it's an electric. Hook the power up to it? Nothing wrong with the 'electric'....DGEV You just bought this carb????? 38 or 32/36? Quote Link to comment
ggzilla Posted August 7, 2011 Report Share Posted August 7, 2011 Adjust the choke to close when it is cold. Then connect it to 12V IGN so it will warm up and open. Quote Link to comment
ggzilla Posted August 7, 2011 Report Share Posted August 7, 2011 For the leak, tighten or replace the accelerator pump diaphragm. A new diaphragm comes in the $20 rebuild kit: Quote Link to comment
lil89ram50 Posted August 7, 2011 Author Report Share Posted August 7, 2011 Yes i just bought this carb, i got it used. its in good condition and i got it at a good price thanks ggzilla! As far as the choke part, i'd like to have a manual choke, the winters here are not great. Id like to control it myself. I had a 38/38 electric choke before and i wasnt too happy with it. Quote Link to comment
Sealik Posted August 7, 2011 Report Share Posted August 7, 2011 Yes i just bought this carb, i got it used. its in good condition and i got it at a good price thanks ggzilla! As far as the choke part, i'd like to have a manual choke, the winters here are not great. Id like to control it myself. I had a 38/38 electric choke before and i wasnt too happy with it. That is good... :) Gets pretty cold here in the winter also...last year was a warm one though....only -32 C.. :D Never had any issues with the electric choke....can be dialed into various start up 'positions'... Quote Link to comment
