weber help
lil89ram50
well i just got my weber bolted down and ready to start, first of all, i need a manual choke, this one is electric. can i convert it with a kit? got a link to a good complete kit?
second concern, it leaks fuel bad! its leaking out of the power valve. even when you barely touch the pedal, it POURS!
this truck runs much better now, but it still leeds this horible leak fixed, and i cannot hold the butterfly's closed by hand every time i start the vehicle cuz i have no choke
  • Replies 9
Since the power valve is located at the bottom of the float bowl, how do you know it is leaking there? It is a tough spot to see. Is your carb off the car? If so, take the top cover off and put fuel in the bowl to verify it is leaking by the power valve.
This diagram may help you describe more accurately where it is leaking
http://www.carburetion.com/diags/3236DGVDiaginfo.asp
Marc in Indy
Datsun 610 Racecar
Yes i just bought this carb, i got it used. its in good condition and i got it at a good price thanks ggzilla! As far as the choke part, i'd like to have a manual choke, the winters here are not great. Id like to control it myself. I had a 38/38 electric choke before and i wasnt too happy with it.
That is good... :)
Gets pretty cold here in the winter also...last year was a warm one though....only -32 C.. :D
Never had any issues with the electric choke....can be dialed into various start up 'positions'...
