mswit209 Posted July 31, 2011 Report Share Posted July 31, 2011 ive been searching all over and cant find the write up that i once found on how to put the pump assembly into a datsun fuel tank if anyone could enlighten me that would be awesome. thanks in advance Quote Link to comment
yellowdatsun Posted July 31, 2011 Report Share Posted July 31, 2011 I've never heard of the 240SX setup being used, but a bunch of us are running a 300ZX pump. Quote Link to comment
DottiBlue Posted July 31, 2011 Report Share Posted July 31, 2011 http://datsun510.arizonagt.org/project/gas_tank/gastank.htm Not from the forum, but maybe it will help. Quote Link to comment
dennis Posted August 2, 2011 Report Share Posted August 2, 2011 This is exactly what is happening to my tank now!!!! I am using the stock fuel level sender because the 240sx sender is not compatible with the stock 510 fuel gauge. Quote Link to comment
tredspeed Posted August 10, 2011 Report Share Posted August 10, 2011 you have to get a programmable gauge or put the 240 setup off to one side when you weld it in so you can use the stock sender or find some odd ball set of resisters to make it read right oh and you can use a 240sx one you actually shorten it less then a 300zx Quote Link to comment
