pl521sss Posted March 11, 2008 Report Share Posted March 11, 2008 Having trouble fitting wheel seals. Ordered front wheel seal from Rock auto and it measures 67mm OD (Beck and Arnley). Old one measures 65mm I believe Rock Auto has given me wrong part or their database is wrong. Can someone please confirm this with their 620 front wheel seal. Thanks Quote Link to comment
mklotz70 Posted March 11, 2008 Report Share Posted March 11, 2008 yep....it's 65mm......67 is the rear outer. You must have gotten the BCA 1974 (timken 1974) ....not sure what they did wrong....double check your order and make sure you didn't click the wrong part. It bugs me how they intermix the front/rears in the listing. Oh well....partsamerica does the same thing. The inner should be easy enough to get locally.....it's the same as the 521 inner seal.....and according to partsamerica(shuck's/kragen)...the seal is used in about a dozen different vehicles. I've bought them locally before. I just got some factory ones from billsqualityautoparts. click on the "see all vehicles..." link http://www.partsamerica.com/ProductDetail.aspx?MfrCode=SKF&MfrPartNumber=18877&PartType=292&PTSet=A At least they should work on the rear end....not a complete waste :) Quote Link to comment
mklotz70 Posted March 11, 2008 Report Share Posted March 11, 2008 of course, I was assuming you meant 620 drum seals :) Quote Link to comment
pl521sss Posted March 11, 2008 Author Report Share Posted March 11, 2008 Thanks Mike I ordered the wrong part, Need glasses. :mellow: Also received those spacers. Quote Link to comment
mklotz70 Posted March 12, 2008 Report Share Posted March 12, 2008 You bet. Been there, done that :) Thanks! Quote Link to comment
