510 Rear Wheel Bearing part numbers
Newbee
Hey,
I am rebuilding my rear suspension and wondered if anyone knows why the bearing part numbers are called out as RW101 for the inner wheel bearing and RW125 for the outer wheel bearing??? when I removed the original bearings they are the same size?? anyone know if the part numbers are correct?
  • Replies 4
Ask and ye shall receive:
Rear Wheel Bearings = Timken 6206 4 Required (These bearings are permanently sealed, and can be found through a bearing supply house, use 6206 or 6206-2RS)
Rear Wheel Seals = Timken 224045 2 Required
Rear Wheel Locknuts = Nissan P/N 43262-21000 2 Required
