troyt Posted July 18, 2011 Report Share Posted July 18, 2011 Looking for a 510 driveshaft, 4 or 5 speed length, poor condition OK, SF Bay area Link to comment
Stupid_fast Posted July 18, 2011 Report Share Posted July 18, 2011 My friend has one!! 4 speed I am unsure if its for a wagon or coupe. Its located in Berkeley, I'll get back to you once I talk to him. Link to comment
fivetengarage Posted July 19, 2011 Report Share Posted July 19, 2011 If Stupid_fast can't hook you up for any reason.I have a stock sedan 4 speed shaft in San Leandro.Cheap! I do believe the wagon driveshaft to be different though. Link to comment
datzenmike Posted July 19, 2011 Report Share Posted July 19, 2011 The goon driveshaft is longer. BTW: If you have a goon and want to install a long 5 speed a sedan driveshaft will fit without shortening. Link to comment
troyt Posted July 19, 2011 Author Report Share Posted July 19, 2011 Thanks guys, I just got called out of town for work for a week, but I'll have forum access. The driveshaft will be for a 280Z 5-speed in my wagon with IRS, so things will fit only by luck. My current Comp CR trans has a custom length Roadster driveshaft with flanges on both ends, but it's coming out for repairs. I need one with a splined end for my back-up tranny. My measurements show that it needs to be 44.5" total length, +/- 1/4". If anyone is willing to measure a stock 4 speed one, or a shortened 510 shaft prepped for a 5 speed for that matter, I'd be curious how they compare. I'll be taking whatever I buy to the shop anyways for balancing since it's for my racecar (sustained high rpms). Link to comment
datzenmike Posted July 19, 2011 Report Share Posted July 19, 2011 CR FS5C71B? Does it have the dogleg pattern? Link to comment
fivetengarage Posted July 19, 2011 Report Share Posted July 19, 2011 Mabey this will help. http://tinyurl.com/4xu6ham Link to comment
troyt Posted July 20, 2011 Author Report Share Posted July 20, 2011 fiveten, thanks for the ref pic, perfect source material. I only determined overall length, but I'm guessing I'm in the "sedan shortened for 5-speed' range, so any driveshaft will due. Makes since because the wagon has the same wheelbase and I transplanted a sedan IRS in it very close to the OE location. I'm interested in your driveshaft, PM me price/contact info if you would, thanks. My back-up trans is an OE 280Z five speed with standard shift pattern and .86OD. I've kept it as my race spare because the ratios for 3rd, 4th, and 5th are basically the same as the Comp CR but since I've never had to use it, I never got around to prepping a driveshaft for it. Link to comment
Stupid_fast Posted July 20, 2011 Report Share Posted July 20, 2011 OK, my friend got back to me. I am almost sure its for a 2/4dr 4 speed. It looked about the same size maybe a little longer than the shortened one for my goon. It is at storage at his moms place in Berkeley, but he now lives in virginia. I can go over and measure it if you want exact specs. I can drive it over to half moon bay on a weekend if you don't mind tipping me $10 for fuel!(takes me maybe 30-40 minute to get to half-moon bay, depending on traffic.) Sale would be cash, then I deliver that to his mom. How much do stock decent shape drive shafts go for? Link to comment
