Z chopper Posted July 16, 2011 Report Share Posted July 16, 2011 I am curious if anyone has supercharged there engines l16, r16, j13 etc...... If yes what supercharger did you use? and any other details to please Quote Link to comment
FoxyRoadster Posted July 16, 2011 Report Share Posted July 16, 2011 since anything for our older datsuns have to be fabricated to fit pretty much any supercharger will do, if you have the SU carbs you have the option of suck through or blow through on the setup. I tinkered with the SC14 from toyota on my R16, would have worked but I'm opting for an engine swap and gonna use the sc14 on the B6 I install. I could harp on and on about the possibilities Quote Link to comment
Z chopper Posted July 16, 2011 Author Report Share Posted July 16, 2011 I was thinking along the lines of an aisin amr500 supercharger I just ran across this http://khairul120y.blogspot.com/?zx=1ab37302aecfb110 Quote Link to comment
FoxyRoadster Posted July 16, 2011 Report Share Posted July 16, 2011 would work if you can find one at a reasonable price.. For how much one of those are you could buy eaton which is a cheaper SC to rebuild and maintain. I got my SC14 for 200 bucks, you should be able to pick up an SC12 from the 4agze for cheap. Quote Link to comment
Z chopper Posted July 17, 2011 Author Report Share Posted July 17, 2011 so far the only toyota sc12 from a 4agze I can find are about the same price as the aisin amr500 Quote Link to comment
FoxyRoadster Posted July 17, 2011 Report Share Posted July 17, 2011 I've found the eaton's for fairly cheap on ebay compared to the one you are mentioning.. can pick up a cheap m90 off an old Buick and rebuild it for under 300 bucks and the 45's are just a little more. Quote Link to comment
Uber Deaf One Posted July 17, 2011 Report Share Posted July 17, 2011 I was toying with the idea of supercharging my KA24 510 when it gets done... Eaton M90 would be perfect. Quote Link to comment
