69dime Posted July 13, 2011 Report Share Posted July 13, 2011 I have a pile of external voltage regulators. I read that the original (non-IC) type had points that could be adjusted to fix them. Can anyone tell me how to fix or test these, or if they want some of them cheap? Or do I throw them away? They cost $30/ea new at O'Reilly's. I have one I pulled from a 620 in a junkyard (I don't have a 620). It has an inline fuse. Does that not work on a 510 or 521? If that's not the case, does anyone want to buy it? I also have another that looks identical that came with other parts. Are they interchangeable between 510 and 521? 620? The 620 looks different. I also have one of the slim style circuitboard/IC type with a Napa part number that matches the 521. Quote Link to comment
ggzilla Posted July 13, 2011 Report Share Posted July 13, 2011 They have varying wire connectors, but otherwise they can interchange. It just regulates voltage. They are adjustable. But if the points are burnt, adjusting won't fix it. They last a long time, mine is 40 years old and still going. But like points in your distributor they do burn out. If it still works, no reason to change them. Keep them for a spare. Quote Link to comment
dat521gatherer Posted July 14, 2011 Report Share Posted July 14, 2011 You can take the cover off and look at the points. All the ones I've looked at looked new. you can adjust them to make your headlights brighter but as far as I've read nobody does that. Great idea for A project and write up for someone to do. Some suggest buying the solid state rather than the point type. I prefer the points type. As far as interchange you can click on the also fits tab on oriellyauto.com when looking at the part. Here is how to adjust in the 521 body and chassis pdf. http://www.olddatsuns.com//620tech.htm Quote Link to comment
banzai510(hainz) Posted July 14, 2011 Report Share Posted July 14, 2011 the 510 and 521s are the same. I prefer the IC board ones. Used VR i say give them away or sell them for 5 $ ,unless new then sell then for what you can get out of them. I had the NAPA Elchin brand made in USA point type mechanical and they are BAD. went thru 2 in 3 years! Never again! Quote Link to comment
