Hardwyre Posted July 2, 2011 Report Share Posted July 2, 2011 So I pulled the 5 speed from a 92 300ZX, but run out of time before getting the clutch and flywheel. For about $50(figuring entry fee and gas) I can get the cluch and flywheel off the car tomorrow from Pick'n'Pull. The flywheel is about $20 and the clutch and pressure plate are another $20 or so. I'm figuring I should go get them, but I'm also curious if, since I'm going to be mating it to a VH45DE, if I should bother with an unknown clutch. Also, are lightened flywheels worth it in a non-race car? What are some good, economic clutch companies? Quote Link to comment
datzenmike Posted July 2, 2011 Report Share Posted July 2, 2011 Flywheels store energy as spinning momentum. This is used to help overcome a stopped vehicle's inertia and get it moving. The problem is that the rest of the time it isn't really needed. The energy used to spin the flywheel could better be used to move the car. Now in a race car that seldom stops you hardly need a flywheel or can get away with a very light one but for a DD with lots of stop and go you shouldn't lighten it that much if at all. So I pulled the 5 speed from a 92 300ZX, but run out of time before getting the clutch and flywheel. Geeez an FS5W30A Z32 5 speed? They are reputed to be able to handle 600+ hp Quote Link to comment
Hardwyre Posted July 2, 2011 Author Report Share Posted July 2, 2011 Flywheels store energy as spinning momentum. This is used to help overcome a stopped vehicle's inertia and get it moving. The problem is that the rest of the time it isn't really needed. The energy used to spin the flywheel could better be used to move the car. Now in a race car that seldom stops you hardly need a flywheel or can get away with a very light one but for a DD with lots of stop and go you shouldn't lighten it that much if at all. I believe I've heard a similar line. Something about a car becoming a pain in the ass to get off the line after lightening up too many things. Thank you for the additional knowledge. Any opinion on the clutch itself? Any way to tell if it's worthless or not? This Datsun in my first manual transmission so I'm sort of learning as I'm going. Quote Link to comment
datzenmike Posted July 2, 2011 Report Share Posted July 2, 2011 If clean and the disc is a tan color, the flywheel and PP surfaces smooth and clean I'd take a chance. If burnt looking, dark perhaps with gouges in the PP and flywheel or cracks or obvious hot spots I wouldn't. Quote Link to comment
Hardwyre Posted July 2, 2011 Author Report Share Posted July 2, 2011 What do you think of this? Deal or pass? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=320718792912#ht_500wt_1182 Quote Link to comment
datzenmike Posted July 2, 2011 Report Share Posted July 2, 2011 Well you usually get what you pay for. It has to handle what 300hp??? Quote Link to comment
Hardwyre Posted July 2, 2011 Author Report Share Posted July 2, 2011 Well you usually get what you pay for. It has to handle what 300hp??? About 300 horse, 330 torque. That ACT clutch kit, minus the flywheel, is about $430 on SummitRacing. I found this review of the ACT clutches. Seems like they're a good mid-level clutch, and the HDSS seems to be the upper end of street clutches. http://www.coximport.com/act/ Quote Link to comment
