nbarter Posted June 28, 2011 Report Share Posted June 28, 2011 Looking for exhaust manifold for A 15 block. I understand there are several versions. A GX ? Have stock intake . Is there a header supplier ? Thanks, Nic Link to comment
ggzilla Posted June 28, 2011 Report Share Posted June 28, 2011 There is no A15 GX. The cast iron exhaust manifolds are several types, most are the same as A14 but some of the A15 are bit larger on the inside. There are header suppliers. The headers are exactly the same as A14 headers and A12 headers. Whether they will fit your vehicle chassis is the question. You can purchase them mail order out of Japan or Australia, and other countries. They are not cheap, but they are good. There is one supplier in USA, price is moderate but reputation is poor. See Headers on Datsun1200.com. Link to comment
wayno Posted June 28, 2011 Report Share Posted June 28, 2011 Looking for exhaust manifold for A 15 block. I understand there are several versions. A GX ? Have stock intake . Is there a header supplier ? Thanks, Nic If I was you, i'd find a stock exhaust manifold and be happy, the stand alone(separate from intake) type are out there, they are more than enough for a street use vehicle, to take advantage of a header on the street, you would likely end up with a wreckless driving ticket, and no license. Where are you located, the United States is fairly big. West coast? Link to comment
BillM Posted June 29, 2011 Report Share Posted June 29, 2011 Nbarter I see that you have this in a Morris- I guess that you know that Robbie Peavy has the jig (from Paul A) to make the exhaust piece to go from the stock A15 exhaust to the Morris exhaust. I can connect you if you need it. BillM Link to comment
