1972 l16 4speed
  • Replies 6
I believe the 2nd set of points switch is also the neutral safety switch on the trans.I could be wrong.But thats how 521's are set up. 2nd points pedal switch, carb switch, trans switch are all hooked together if you unhook one, the neutral safety wont work unless you bypass them somehow.
There is no neutral safety switch on a stock 521. The lowest switch on a stock 521 transmission is the reverse light switch. One of the wires going to it is hot, whenever the key is on.
The other two switches on the transmission used to activate the second retarded set of point. This system also uses a throttle switch, a clutch switch, and a part throttle switch on the stock carburetor.
If your 521 no longer has the stock distributer, or transmission, or carburetor, this system is not functioning anymore.
