Dual Carbs
yoursurfer
  • Replies 5
Ok, on yours it appears to have a few extra parts bolted to the intake that may or may not be smog related. Compare to mine & see the diff. They may perform fine & may indeed need them to work right not really sure. MIne came like you see them & the red hose will be removed & 2 small triangle block off plates will be screwed down to plug the gap.
