4.62 ring and pinion
  • Replies 5
From my notes 620 long beds were 4.62 ratio as well.
4.88 are eadily available in 520 & 521 with the 1.3L. A 320 center (4.88) can be used if you swap out the side gears to the later truck spline.
I don't think the long beds got the 4.625s. Only autos up to when the L20B came in.
The '73 620 with an L16 and an automatic also has the 4.625 gear ratio. The applied model is: PL620KTU.
I think you're right. Forgot about the early L16 autos.
