HELP HELP HELP WITH TACH INSTAL!!!!
HELP!!! I've been trying to install an aftermarket tach to my KA in my 620. I've tried tapping into the negative side of the coil and I get nothing at all on my tach. Its a brand new tach too. It is the green w/black wire on the coil correct? Or can I tap right out of the computer? If so which wire is it? I tried doing some research and I do believe it is the yellow w/red for the tach signal. Can someone help a brotha out?
  • Replies 6
