the510 Posted May 17, 2011 Report Share Posted May 17, 2011 so my left turn signal works perfect. but when i click to the right the dash arrow lights up solid green instead of blinking, and the rear right tail lamp lights up solid red. once every 10-15 secounds you can hear the click in the dash indicating that its on. what could cause this?? o yea its on my 1979 king cab 620 Quote Link to comment
Javin Posted May 17, 2011 Report Share Posted May 17, 2011 Make sure all your lights on the right side work. If they are good just spend a few bucks and get an electronic flasher module :P Thats what I did. the flashers work on some sort of electrical current to make them flash. if the correct amount of lights arent present it throws it off. Someone can chime in with the technical jargon. Quote Link to comment
datzenmike Posted May 17, 2011 Report Share Posted May 17, 2011 One post is enough. I deleted the other. Quote Link to comment
