Nice140Y Posted May 10, 2011 Report Share Posted May 10, 2011 Hi all, I am going to be replacing all the bushings in the front of my 510. Along with a thicker sway bar (22mm) and shorter springs. I am running 14' rims with 195/60/R14 tires on them Can anyone tel me what the specs would be to align my car properly? Thank you. Quote Link to comment
jesusno2 Posted May 10, 2011 Report Share Posted May 10, 2011 I like to use a touch of toe in about 2 degrees caster with bushings, and 1 degree + camber or 1.5 is good to. To much caster will make the steering heavy and wear the bushings pretty fast. I'm no alignment expert but that seems to be about ball park figures. Quote Link to comment
sssr20det510 Posted May 10, 2011 Report Share Posted May 10, 2011 Look on the dime quarterly there are specs on there for street and race 510 Quote Link to comment
ggzilla Posted May 10, 2011 Report Share Posted May 10, 2011 While the 1969 service manual suggests up to 1 degree positive camber is in spec, I would adjust it to the far side of the spec -- put it at zero camber. A lot of guys ignore the specification and adjust for negative camber (-ve) although that will wear the tires on one side. You have to fit adjustable strut tops or something, as it is normally not adjustable. Quote Link to comment
Nice140Y Posted May 11, 2011 Author Report Share Posted May 11, 2011 Thanks guys! The problem I am having right now is that my front passenger tire (only) is wearing out on the outside about 2.5 inches wide. It is noticeable. I feel it in the steering. It pulls a bit to the right. Is this something that can be adjusted? Quote Link to comment
ggzilla Posted May 11, 2011 Report Share Posted May 11, 2011 It can be fixed. Either adjusted or what is normally done is to replace whichever parts are bent or out of spec. A good wheel alignment place will know what to do. Quote Link to comment
