frink84 Posted May 5, 2011 Report Share Posted May 5, 2011 picked this up a month or so ago, slowly bringing it up to shape and fixing the PO's mistakes. its a 72 620 with a weber 32/36 and a L20b. 4-speed manual. no radio. half-done flat black paint. suuuuper dark tint. when i picked it up: a week or so later, more black: today, all black! so far i have: plugged in the speedo, replaced all the dash bulbs to gain interior lights, installed working door locks, installed a tach, installed throttle return spring, fixed the vacuum leaks on the carb, tuned the carb, recentered the drop blocks, installed new flowmaster exhaust (50 series with 2.25" tube), removed overspray from lights so they light up, and adjusted the brakes. i picked up a set of 17x7.5 black steelies from an escalade that will go on soon. also scored a 280z master cylinder at the jy, and a set of 300sz front calipers so i will be doing the bebani disc brake conversion as well. other than that, a stereo, lighter tint, and a bit of bodywork and it will be a fun little driver. Quote Link to comment
metalmonkey47 Posted May 5, 2011 Report Share Posted May 5, 2011 Looks good man! Good luck! Quote Link to comment
831Sunny Posted May 5, 2011 Report Share Posted May 5, 2011 looks totally awesome.. only thing i disagree is the side mirror's but to his / her own... keep up the good work Quote Link to comment
frink84 Posted May 5, 2011 Author Report Share Posted May 5, 2011 looks totally awesome.. only thing i disagree is the side mirror's but to his / her own... keep up the good work yea, those were the only mirrors it came with, so that is what it has now. eventually it will get door mirrors Quote Link to comment
frink84 Posted May 6, 2011 Author Report Share Posted May 6, 2011 started it up this morning and it died after i backed it out of the garage. fuel pump not getting any fuel but the tank is a good 80% full.... time to drain and replace lines! Quote Link to comment
