BRE_dAtSuN Posted April 23, 2011 Report Share Posted April 23, 2011 l16 just swapped dual mikuni 44's idles fine revs good.. as soon as u put it in reverse or drive it backfires though carb and has no power and stalls....NEED HELP ASAP Quote Link to comment
metalmonkey47 Posted April 23, 2011 Report Share Posted April 23, 2011 Check the timing? I don't know auto trans, but I know that doesn't sound good. Quote Link to comment
datzenmike Posted April 23, 2011 Report Share Posted April 23, 2011 Don't know the Mikunis at all. Do they have a choke or some way to richen the mixture on start up? If so, try that and see if it helps. It shouldn't be lean if coming off an L20B but it sounds like it. Assume the L16 was in good tune before the swap? Are you running vacuum advance from the manifold? Quote Link to comment
BRE_dAtSuN Posted April 23, 2011 Author Report Share Posted April 23, 2011 hey guys thanks... yea it had nothing with mixture if anything we had to lean it out a grip my car would burn the gas but the stock l16 with points it was smoking it out... we had changed the plugs and unplugged the wires and mixed the last two on accident and didnt realize until we reinstalled his weber 32/36 and the motor still ran rough...so we changed everything back carb manifold linkages and pedals and turned right on perfectly and revved freely =) Its always the smallest things Quote Link to comment
jdmdime Posted April 24, 2011 Report Share Posted April 24, 2011 Hah noob mistake. Hey I forgot the meter to sinchronize the carbs Quote Link to comment
BRE_dAtSuN Posted April 24, 2011 Author Report Share Posted April 24, 2011 yea i know... i can send it to you...also i was thinking of buying a some bigger jets for the weber at that 1 shop u said.. do u know if they said rebuild kits there too ? Quote Link to comment
jdmdime Posted April 24, 2011 Report Share Posted April 24, 2011 Yeah they usually stock all that stuff at top end. Quote Link to comment
