Hoosier77 Posted April 17, 2011 Report Share Posted April 17, 2011 Anyone ever had trouble flaring the stock brake line on a 620? I have used double flaring tools before with no problem. It seems as though this type of brake line is hard as a rock, I have chucked it up in 2 different double flaring tools and tightened them all to hell, the line slips everytime!!!!!!!!!! I swear I tightened the shit up with a breaker bar, it will not get any tighter!!!!!!! I cannot flare the first flare. WTF? Any help or experience? Quote Link to comment
mklotz70 Posted April 17, 2011 Report Share Posted April 17, 2011 I did this vid awhile back. It might help. http://community.ratsun.net/topic/17033-brake-tube-flaring/ It sounds like the tubing is slipping in the holder? Maybe you can clamp it tighter with some vise-grips....kinda like I use the vise to do in the vid. If that doesn't work, you might just consider buying new line....it doesn't cost much. Quote Link to comment
Hoosier77 Posted April 17, 2011 Author Report Share Posted April 17, 2011 I used a big bar to tighten the holder, if i were to get the molecules of the holder any closer together then it would be welded!!! i tightened it up so much I was in risk of stripping the threads! Has anyone ever flared the stock lines before? I have flared brake lines many times but never had this much trouble, I used two different tool sets. Is the stock line wall thickness a lot more than after market? WTF!!! Quote Link to comment
yello620 Posted April 17, 2011 Report Share Posted April 17, 2011 Flaring old brakes lines is almost always harder than flaring new brakes lines, not sure why, but i have had the same problems. It can be done though. Might try stightly warming up the brake line to soften it just a little? Maybe. At the same time that might just make it slip in the tool that much easier. Good luck, old lines suck. Quote Link to comment
