a10 wagon Posted April 16, 2011 Report Share Posted April 16, 2011 my battery keeps dying becaue its not getting power from the alternator but the alternator is putting out over 15 volts.i took it to the auto parts store to have them test it and they said it was my alternator.but the alternator is putting out power. so is over 15 volts to much voltage or is there some fuseable links between there.does anyone have the wiring digram for a z20s in an 80 510.thanks to all that help. Quote Link to comment
metalmonkey47 Posted April 16, 2011 Report Share Posted April 16, 2011 Wait, your batterys not taking a charge? Is that what you're saying? What kind of battery do you have? How old is it? Quote Link to comment
a10 wagon Posted April 16, 2011 Author Report Share Posted April 16, 2011 no the battery isnt taking a charge at all from the alternator. its an everstart battery.i dont know how old the battery is:( because it was in it when i bought the car last july but i was told the battery was fairly knew. by the previous owner Quote Link to comment
datzenmike Posted April 16, 2011 Report Share Posted April 16, 2011 Clean both battery terminals and the negative terminal where it bolts to the head, and the positive cable where it bolts to the starter. If the battery dies over night you may have a draw that drains it. Charge the battery and disconnect the cable over night. Try it in the morning. If dead the battery isn't holding a charge. If the car starts and works normally you have a parasitic draw that needs to be found and eliminated. I got a car once that did this. The previous owner had the horns stick on so he just pulled the wires off them. The problem was that the relay was still on and would drain the battery over night. You may have an AMP that is on all the time. Brake lights on all the time? Quote Link to comment
a10 wagon Posted April 17, 2011 Author Report Share Posted April 17, 2011 ok i'll clean all the terminals tommorow and check to see if anything stays on all the time.thanks for the responses Quote Link to comment
