pickleweasle Posted April 14, 2011 Report Share Posted April 14, 2011 I'm doing a 5 speed conversion in my 620 when I toke the flex plate off there was a plate on the back of the crank does it stay or go when I put the flywheel on I'm assuming I leave it off cause the pilot bushing doesn't fit. Quote Link to comment
zerow Posted April 14, 2011 Report Share Posted April 14, 2011 I'm doing a 5 speed conversion in my 620 when I toke the flex plate off there was a plate on the back of the crank does it stay or go when I put the flywheel on I'm assuming I leave it off cause the pilot bushing doesn't fit. Remove the plate, but you will have to add a pilot bushing. Quote Link to comment
datzenmike Posted April 14, 2011 Report Share Posted April 14, 2011 The spacer plate has to be removed. I don't think the L flywheel will even go on with it there. The Z series clip onto the crank and they definitely won't fit on. The pilot bushing goes into the very end hole on the crank. It's already lubed so don't grease it. Hammer in carefully with a block of wood. Quote Link to comment
pickleweasle Posted April 14, 2011 Author Report Share Posted April 14, 2011 Awesome thanks guys I thought that was right but I wanted to make sure before I got it togeather. Quote Link to comment
pickleweasle Posted April 14, 2011 Author Report Share Posted April 14, 2011 Also what fluid does that tranny take I haven't been able to find anyone who could tell me for sure Quote Link to comment
