OlyRon Posted April 10, 2011 Report Share Posted April 10, 2011 I hope someone can help me with this. I am in the middle of repairing a series 60L dogleg 5-speed. The countershaft rear caged needle bearing was completely trashed, and damaged the thrust washers for the countershaft. I was able to find a good used 37 X 28 x 20 mm bearing (no longer available new anywhere that I can find), but so far no thrust washers. I need a standard rear washer and a #8 front washer (could probably get by with a #6 or #7). Anyone with parts trannies out there? Used would be ok. The front should measure about .098", the rear .090". I could also use a good idler gear, as mine is a bit rashy. Any help is appreciated. Ron Quote Link to comment
Morrisun Posted April 10, 2011 Report Share Posted April 10, 2011 Ron: Google -Rock Auto, Nissan, 1982 pick 210 Delux, 1.5L under transmission - manual they list counter shaft bearings. I didn't see shims you maybe able to get them at the dealer- If dealer uncooperative let me know, the dealer down here has been helpful. They also list countershaft thrust bearing. Doug Quote Link to comment
datzenmike Posted April 10, 2011 Report Share Posted April 10, 2011 I hope someone can help me with this. I am in the middle of repairing a series 60L dogleg 5-speed. The countershaft rear caged needle bearing was completely trashed, and damaged the thrust washers for the countershaft. I was able to find a good used 37 X 28 x 20 mm bearing (no longer available new anywhere that I can find), but so far no thrust washers. I need a standard rear washer and a #8 front washer (could probably get by with a #6 or #7). Anyone with parts trannies out there? Used would be ok. The front should measure about .098", the rear .090". I could also use a good idler gear, as mine is a bit rashy. Any help is appreciated. Ron Rear counter thrust washer ....................... 32284 - H9000 (about $15) Front thrust washers.................................. 32224 - H7200, H7201, H7202, H7203, H7204, H7205, H7206 and H7207 (sorry I don't have the thicknesses to go with the numbers, and about $12 ea.) Reverse idler gear?.................................... 32282 - H9000 (about $140) Quote Link to comment
OlyRon Posted April 10, 2011 Author Report Share Posted April 10, 2011 Thanks very much. And from Doug, I have the thicknesses that go with those part numbers. I need one of the 32284 - H9000 and one of the 32224 - H7204. Must pass on the idler gear -we'll see how the one I have works and go from there. How should we proceed with this? Ron Quote Link to comment
