How Many Lights Does The 620 Tach Use??
  • Replies 5
What's The Difference Between A 1200 Tach And A 620 Tach?
1. Font is slightly different
2. 620 uses neg trigger like most tachs (wired to - terminal of the coil), 1200 uses induction loop trigger (wired into + circuit of the coil)
They bolt in the same and looking nearly identical. newer 1200s e.g. JDM pickups use the 620 tach.
