bravohotel Posted April 4, 2011 Report Share Posted April 4, 2011 i need to hook up factory 510 tach to the ka harness - i need help anybody got info? thanks Quote Link to comment
Creepy Cruiser Posted April 5, 2011 Report Share Posted April 5, 2011 S13 or S14 kade? Quote Link to comment
78kingcab Posted April 10, 2011 Report Share Posted April 10, 2011 it is s13...... The tach (for the factory 510 one) is pretty easy also on the s13 motor. On the back of your tach it will have two white wires, all you do is unhook the + from the coil and run it to the tach through the white wires, and then back to the coil, (essentially putting the tach in line with the power to the coil.) Then just hook the other wires up like normal, to the 510 harness. so the question is what wire is the + on coil......i just dont remember.... Quote Link to comment
