Rollover_Red Posted March 7, 2011 Report Share Posted March 7, 2011 ok so i just got to my dads house here in sac and i got a heater core and after flushing to core and checking for leaks and testing the fan, the damn thing works! but im running into a few problems..... one, i have no idea where it mounts under the dash, i dont know if im missing parts and im cold..... anyone have pics of where the upper part of the heatercore mounts to the underside of the dash? Quote Link to comment
benzo Posted March 7, 2011 Report Share Posted March 7, 2011 The unit mounts to the fire wall If I remember and then two bolts to some brackets under the dash and then you have one hose on the passenger side and then another that goes to the valve on the drivers side. there are also two rubber vent tubes that connect to the unit that goes to the ducting. you should also have two cables that go for controlling heat and for either vent or floor. Quote Link to comment
Jester Posted March 13, 2011 Report Share Posted March 13, 2011 There are two bolts that go through the fire wall and two that connect to the brackets, as said above, just under the center of the dash. Quote Link to comment
Rollover_Red Posted March 24, 2011 Author Report Share Posted March 24, 2011 ok i got the heater in and working, but i dont have the cables to make it cool, and i also dont have the vents, hoses or anything to divert the direction of heated air...... i just have the heater core and the speed switch. it works great, but it just sits in there. ill post pics tomorrow of what i have in the car.... Quote Link to comment
