710 (160J) Tachometer connection help???
  • Replies 5
Looks like the induction type used on the early 620s
Look at the 12:00 position on yours..
Looks like the same 4-5 wire on the 620...
Not sure but I think the 4-5 wire is the trigger for the tach. It simply loops through that connection ti induce a signal. Not at all sure if it's in series with the coil neg to points or in parallel with it. Datsunaholic might know.
Hey man, sorry I couldn't wait for your reply, I connected it and it worked, but its kinda laggy, its takes a long time to get to its original place, sometimes it doesn't and I have to shake the gauge to get it to the current engine rpm. Could it be fixed?
Thanks
You will have to look for a speedometer calibration near you. They have the proper tools to calibrate the tach. DO NOT do it yourself! You run the risk of ruining it. Good Luck!
Thanks man, I will see if I can find one. The problem was that there is so much dust in the tachometer, I sprayed a little gasoline on it and the niddle worked correctly (gets back to the current rpm instead of hanging where it reached), and thanks for the hint, PUSH ME LUCK!!!!!
