phatdave Posted March 4, 2011 Report Share Posted March 4, 2011 Well,its starting.The problems are arising.My clutch pedal won't return to the up position.In other words I push it in it wont come back out. So it wont disengage. What the scoop ? Thanks. Quote Link to comment
banzai510(hainz) Posted March 4, 2011 Report Share Posted March 4, 2011 isnt there a spring to lift the pedal arm up? Have you ck your fluid in master cylinder, ck your slave cylinder. look inside of the truck behind master cylinder if wet maybe its bad. Try rebleeding the system Quote Link to comment
MicroMachinery Posted March 4, 2011 Report Share Posted March 4, 2011 Check the slave cylinder on the transmission as well. If it's leaking, then you'll be running out of fluid, and losing pressure. Quote Link to comment
phatdave Posted March 4, 2011 Author Report Share Posted March 4, 2011 Okay. Thanks. Quote Link to comment
phatdave Posted March 5, 2011 Author Report Share Posted March 5, 2011 Thanks men. Clutch cylinder was pissin out fluid. I guess Ebay will be my best bet for a new one !? Quote Link to comment
ggzilla Posted March 5, 2011 Report Share Posted March 5, 2011 Rockauto.com O'reillys.com Autozone.com Quote Link to comment
ggzilla Posted March 5, 2011 Report Share Posted March 5, 2011 $32 at Rockauto.com Quote Link to comment
