Sr20Det $250
Almost complete SR that needs a rebuild it does not have, coilpacks, injectors, harness, tranny, turbo. the motor is sludged which caused the cam squirters to clog so it messed up the head. Buy this for parts it does run but the cam squeaks and you can hear it so it needs a new head.
$250 firm Call or text and we can talk. 2067885406
Water pump
PS Pump
ThermoStat
Stock Downpipe with O2
Both manifolds
new exhaust gasket
alternator
belts
block
AC unit
All Brakets for pumps
Basiclly everything Excluding coilpacks, injectors, harness, tranny, turbo
  • Replies 7
Need to post on where your location is
agreed, location and oics if you could, cuz that will deffinately help the sale...... also before mike shows up, this post is in the wrong section, it should actually be in the "datsun parts for sale" section.... proper posting will also boost interest
googled the phone # and got this info.
City: Mukilteo/Edmonds
State/Province:WA
Price:???
Item Description: I need a window regulator for an s13 coupe. Call/TXT 206-788-5406 thanks
