SRSANDS Posted March 2, 2011 Report Share Posted March 2, 2011 Hey guys looking to sell my 69 Datsun 521. Some of you know this truck from my project posts as well as posts from Datdoug. I picked this truck up from Datdoug with no motor and interior. Since I bought this truck I have replaced many parts and daily drive it. It is very reliable and runs good. Was originally a J series truck with 4 speed. New motor mounts and trans mount for LZ22 and 5 speed The good.... Fresh LZ22- Rebuilt bottom end, Fresh rebuilt U67 open chamber (Tdajj can vouch this motor is new) Compresion accross the board is excellent, Oil pressure is also good New oem timing set New Alternator New plugs cap and rotor New water pump and belt Matchbox dizzy Clean excellent condition gas tank New brakes, wheel cylinders, master cylinder and soft lines New clutch, pilot and throw out bearing 8" Chevy Ralley rims with stretched 195/55/15 tires Mint conditon bench seat Carpet kit All lights and controls work Weber 32/36 with bigger jets Extra early model L16 manifold and downpipe (not installed) Rewrapped dash 3" lowering blocks 5 speed trans 3.8 gears from 720 excellent condition fuse box and wiring engine comp complete cut and welded extended shock mounts new front shock inserts Autometer volt, oil, and water gauge Mini tach on column 2 piece driveline Truck is pretty quick....toss a 38/38 or side drafts on it and it would rip Fires right up Idles perfect once warmed up Excellent mint condition heater box that works great Red LED glowing speedo..Alpine cd player The bad: Truck tracks ruts with wide tires Needs new glass seals odometer doesnt work Quarter size rust hole in driverside floor (I can patch it up if interested) Body has outdents in bed Truck is in its second patina :( Still looks cool Infamous light oil mist from LZ timing cover PO before Datdoug removed helper spring, so axle wraps a little when getting on it- I have a full set 720 leaf springs to put on I will give you PO cut dash for a cd player to fit This truck looks good and drives better. Very fun truck. :cool: Ask Datdoug , he is a Ratsun member that has seen the truck in person since I have done all this work Asking 1500 obo, shoot me a email @ srsands78@hotmail.com or text or call 253-318-8787 if you want to come see it Thanks Shawn Sands Link to comment
DISLEXICDIME Posted March 2, 2011 Report Share Posted March 2, 2011 How much traid in will you give me for my 720 ???? Link to comment
SRSANDS Posted March 3, 2011 Author Report Share Posted March 3, 2011 Well over had two people come look....but no ratsun members:( sorry no trades for 720s :) have to many Link to comment
fisch Posted March 3, 2011 Report Share Posted March 3, 2011 Such a bitchin 521 Sr! Is there a thread about it? I know Jun could use this LZ22 in his green goon! Link to comment
LeX Posted March 4, 2011 Report Share Posted March 4, 2011 think i could drive this thing cross country heh? Link to comment
SRSANDS Posted March 6, 2011 Author Report Share Posted March 6, 2011 *SOLD* To a future new Ratsun member! I will let him introduce.....good Guy. Link to comment
