The datsun kid Posted January 24, 2011 Report Share Posted January 24, 2011 hey guys so the other day i go and start my truck and the choke is on and it runs fine then i push the choke in it almost dies like diesling almost then u pull the choke out again and it picks back up!?! i have a l16 with a brand new weber 32/36 kinda confused any help would be good thanks Quote Link to comment
ggzilla Posted January 24, 2011 Report Share Posted January 24, 2011 Was it running OK before? Classic symptoms of a vacuum leak. Perhaps a hose fell off, or cracked or burned. Inspect them carefully. If the new carb has never run correctly, it may have been put together incorrectly. Quote Link to comment
banzai510(hainz) Posted January 24, 2011 Report Share Posted January 24, 2011 if it has a a thin carb adapter it could have cracked thus no idle. You overtighten the nuts? you adjust the mixture setting and speed screw setting?Its could be this if its brand new. If running ZOk before then something is loose like intake or carb adapter Quote Link to comment
The datsun kid Posted January 24, 2011 Author Report Share Posted January 24, 2011 yea it ran great before it just randomly started doing it so im thinking it may be a vacuum leak il check it out when i get home thnx guys Quote Link to comment
