brodster Posted January 20, 2011 Report Share Posted January 20, 2011 I am gathering all my parts to take to the machine shop for a engine balance. I have or THOUGHT I have everything. My L20b came of a vehicle with an automatic tranny, but I am converting over to a manual. I bought a super nice lightened 225mm lightened flywheel from A1Machinsta and all the necessary bolts, etc. Perhaps it isn't a big deal, but I was looking at some diagrams that show a shim between the crank and flywheel: http://nissan4u.com/parts/pickup/us_720/1980_1/type_16/engine_mechanical/piston_and_crankshaft_and_flywheel/ A couple of the diagrams show a crankshaft Pin that goes from the crank to the flywheel as well. Do I need these things? Maybe it won't matter for the balance too much. Never had one done before. Thanks Quote Link to comment
darrel Posted January 20, 2011 Report Share Posted January 20, 2011 The autos had the shim, keep it off for the manual. The pin may have come from a diesel engine. Speaking from experience on z cars, the diesel crankshaft has a dowl in the end of the crank to index the flywheel. Your non diesel crankshaft won't have it. Quote Link to comment
datzenmike Posted January 20, 2011 Report Share Posted January 20, 2011 Don't worry about the spacer, that's only for use on an automatic flex plate. Your flywheel won't even fit on with it in place. Just pry off or leave off. The pin is likely one of the three dowel pins that stick out of the flywheel to align the pressure plate in position. Quote Link to comment
brodster Posted January 20, 2011 Author Report Share Posted January 20, 2011 Thanks guys. That is what I thought. The pin in a couple of couple of pictures looks different and appears to be listed different than the clutch/flywheel pin. I don't think there is a spot for it anyways, so I will forget about. Quote Link to comment
SHAMUS'WAGON Posted January 20, 2011 Report Share Posted January 20, 2011 If you do find the shim. Shoot me a price to 98683 since your not gonna need it anyway. Quote Link to comment
