ricardo Posted December 21, 2010 Report Share Posted December 21, 2010 hi amigos,i installed and synchronized both carbs.the car runs and idles great,what im confused about is that the rpms drop when i close the hood and ill pop the hood back up and the rpms go rigth up.why is this happening and what is the solution.please help,god bless. Quote Link to comment
Stupid_fast Posted December 21, 2010 Report Share Posted December 21, 2010 more airflow with the hood open? I could be wrong, but I think this topic belongs in the "engine" section, not the howto. Quote Link to comment
datto510 Posted December 21, 2010 Report Share Posted December 21, 2010 Maybe the hood is is hitting part of your linkage? Quote Link to comment
justin 620 Posted December 21, 2010 Report Share Posted December 21, 2010 That deffinently sounds like an air-flow problem. Did you hear any noises you would expect to hear if you hit the hood on any linkages? Quote Link to comment
ricardo Posted December 21, 2010 Author Report Share Posted December 21, 2010 i have a center pull linkage,its doesnt hit the hood when i close it.i agree that when i close the hood their is less air flow,im going to set my idle at a higher rpm and see how that works.thank you guys for your help. Quote Link to comment
banzai510(hainz) Posted December 21, 2010 Report Share Posted December 21, 2010 .i agree that when i close the hood their is less air ???????? WTF!!!!!! If this is true it would happen on all my sidedraft equip cars. There alot of air in there. something is binding. grease up the throttle cable also. dial the timming up to 12-15 first. Quote Link to comment
ricardo Posted December 21, 2010 Author Report Share Posted December 21, 2010 banzai510,i will try what you advice.ill keep you posted,Thanks alot guys i appreciate the advice. Quote Link to comment
banzai510(hainz) Posted December 21, 2010 Report Share Posted December 21, 2010 return spring consistant? Quote Link to comment
ricardo Posted December 23, 2010 Author Report Share Posted December 23, 2010 hey guys,i finally figure out what was causing my idle to be off when i closed the hood,my hood was hiting the vacuum hose.the hose had a crack that would expand when the hood was up against the hose.i replaced the hose and the check valve.idles great,thank you guys! Quote Link to comment
