dual mikuni phh 44
ricardo
hi amigos,i installed and synchronized both carbs.the car runs and idles great,what im confused about is that the rpms drop when i close the hood and ill pop the hood back up and the rpms go rigth up.why is this happening and what is the solution.please help,god bless.
  • Replies 8
i have a center pull linkage,its doesnt hit the hood when i close it.i agree that when i close the hood their is less air flow,im going to set my idle at a higher rpm and see how that works.thank you guys for your help.
hey guys,i finally figure out what was causing my idle to be off when i closed the hood,my hood was hiting the vacuum hose.the hose had a crack that would expand when the hood was up against the hose.i replaced the hose and the check valve.idles great,thank you guys!
