Mini-L320 Posted November 30, 2010 Report Share Posted November 30, 2010 Ok so everytime I burnout in my 210 and both tires grab at the same time the car starts to bounce/shake alot. But when only 1 grabs car burnouts Awesome and smooth. Will Stiffening Rear Suspension Eliminate this problem? By Spring time I plan on swapping out the Stock Open Diff Rear End on my 210, and putting an LSD from a 85 GSL-SE Rx7, SO Yeah MORE BURNOUTS!!! :D Quote Link to comment
PurePontiacKid Posted November 30, 2010 Report Share Posted November 30, 2010 quit doing burnouts and I think that should possibly rid you of your problem. Quote Link to comment
charlie6178 Posted November 30, 2010 Report Share Posted November 30, 2010 Quit doing burnouts??? Is this guy serious??? Quote Link to comment
jnec510 Posted December 1, 2010 Report Share Posted December 1, 2010 those are straight axle in the rear, right? if to just pick up some traction bars i used to have a set for my 510 goon. worked awsome. and burnouts for the win. Quote Link to comment
datzenmike Posted December 1, 2010 Report Share Posted December 1, 2010 The two ten is coil spring and four link the best defense against axle wrap. The rubber bushings (8) on the link ends are worn or soft or not stiff enough allowing some small forward/backward shuddering of the axle housing. Stiffer shocks (or even new ones) will help. You could also experiment with different tire pressures even different from side to side. Quote Link to comment
Mini-L320 Posted December 1, 2010 Author Report Share Posted December 1, 2010 WHAT!!! QUIT BURNOUTS!!! :hyper: I'll rather Crash and Kill my Self in a Datsun, Thank you. :fu: Yeah I just added new Rear Shocks but maybe i will find some stiffer springs and go with the KYB Gas Shocks Instead. My Rear Tire Pressure is set at 30psi Quote Link to comment
Mini-L320 Posted December 1, 2010 Author Report Share Posted December 1, 2010 How many LB's (pounds) should I get the rear Spring for? I saw in the Haynes Manual that these 210 came with 85lb's for stock rear spring rate. Im thinking of going with 150lb's Coilovers http://cgi.ebay.com/ebaymotors/UPR-79-04-Ford-Mustang-Rear-Coil-Over-Kit-150lb-Springs-_W0QQcmdZViewItemQQhashZitem4cf16a2174QQitemZ330467778932QQptZRaceQ5fCarQ5fParts Quote Link to comment
datzenmike Posted December 1, 2010 Report Share Posted December 1, 2010 The rear spring will affect ride.... you know like when the car is actually moving???? :D Stiffer springs aren't really going to do much for a burn out sitting still. Vibration? Check your front and rear U joints. Also inspect your four link for bushing damage or looseness. Pry on them with a 2x4.Try increasing tire pressure? Quote Link to comment
Mini-L320 Posted December 1, 2010 Author Report Share Posted December 1, 2010 The rear spring will affect ride.... you know like when the car is actually moving???? :D Stiffer springs aren't really going to do much for a burn out sitting still. Vibration? Check your front and rear U joints. Also inspect your four link for bushing damage or looseness. Pry on them with a 2x4.Try increasing tire pressure? Nothing is damaged or loose in my rear end. The whole back end Bounces when both Tires burnout but when only one burns out the car sits there smokin em Smooth, you cant even feel that its burning out when only one spins. Quote Link to comment
