LeDevil Posted January 18, 2008 Report Share Posted January 18, 2008 Well after mounting up my 16's I went for a drive last night and noticed that my truck pulls real hard to the left now. :confused: I checked for rubbing binding and found nothing. Tires are all the same size same inflation PSI same tire wear. It didn't do it when I had my 14's on there. Could it be because the new tires are wider and bigger which made the problem noticeable? Well thanks in advance for any help. Quote Link to comment
lancekilgore Posted January 18, 2008 Report Share Posted January 18, 2008 try switching the two front tires. Some times the bandsin the tire cause a problem if you switch and it now pulls to the right then there is a problem in the tire if not and it still pulls to the rleft then it is in the supension. Lance Quote Link to comment
yello620 Posted January 19, 2008 Report Share Posted January 19, 2008 Exactly what lance said. Are they directional tires? Still ok to switch them side-to-side for testing purposes. Cant recommend leaving them that way. I have been told that you can run them either direction, but i beleive the manufacturer made them directional for a reason. Used to have to deal with this a lot when i was doing alignments for a living. Jason Quote Link to comment
DISLEXICDIME Posted January 19, 2008 Report Share Posted January 19, 2008 when the tire shop putt in my directional tires back words my car had a bad vibration Quote Link to comment
