Gearheadcurt Posted November 11, 2010 Report Share Posted November 11, 2010 My wipers only work every once in a while is there a common problem with these? Quote Link to comment
H5WAGON Posted November 11, 2010 Report Share Posted November 11, 2010 My wipers only work every once in a while is there a common problem with these? Your lucky they work.....My wiper linkage is frozen....Motor I still need to look at...:unsure: If the motor works and everything moves, thats a good start. Could just be a bad switch or the wiper motor and connectors need some TLC.(Cleaning) Do they work really good when they work, or are they slow? Both settings Low and High. Quote Link to comment
Gearheadcurt Posted November 12, 2010 Author Report Share Posted November 12, 2010 ya it works fine when it does work, I'll use a volt meter later when I have time what exactly is the black wire thing going to the back? to a silver thing Quote Link to comment
hang_510 Posted November 12, 2010 Report Share Posted November 12, 2010 the motors commonly have 2 speeds... slow and slower. ensure all the connections are clean, and the ground connections are solid. what exactly is the black wire thing going to the back? to a silver thing the thingamajig, dont break it!!! Quote Link to comment
deadmonkey Posted November 13, 2010 Report Share Posted November 13, 2010 I had an issue with mine too, but I carefully pulled apart the switch (has little bendy tabs), cleaned it and put some grease there where the old grease had dried up. Works perfectly now. When you are prying on the tabs or bending them back, be careful the force you apply on them cuz you can crack the old plastic if you pinch it wrong. Quote Link to comment
Gearheadcurt Posted November 14, 2010 Author Report Share Posted November 14, 2010 oo ok I'll try my hand at it thanks for the info Quote Link to comment
