Dazilla Posted November 5, 2010 Report Share Posted November 5, 2010 Hi, Guys!! I have a 521. Were can I buy rear leafspring bushes? also chackle bushes too... thank you Quote Link to comment
MicroMachinery Posted November 5, 2010 Report Share Posted November 5, 2010 Here are some leaf bushes. Quote Link to comment
izzo Posted November 5, 2010 Report Share Posted November 5, 2010 Those will cost you two in a bush also... Good luck coffin up the paper for that Quote Link to comment
datzenmike Posted November 5, 2010 Report Share Posted November 5, 2010 A bird in the hand is worth two bushes. I'll look up some part numbers when I get home. The 620 may fit. ...and its shackle. I'll look then up too. ____________________________________________ The front spring bushing one each side is, I think, 55045 20400 about $20 ouch For the shackle there's an A and B side on each one. I've had the 620 apart and they just push in from each side. You'll need two of each if doing both sides. The tops weren't listed but likely the same. If tight to get in use a little vegetable oil not motor oil. Also do not fully tighten the nuts until the vehicle is off the jack stands and sitting on it's wheels. 55046 20400 A about $4 each. 55047 20400 B Quote Link to comment
Dazilla Posted November 11, 2010 Author Report Share Posted November 11, 2010 A bird in the hand is worth two bushes. I'll look up some part numbers when I get home. The 620 may fit. ...and its shackle. I'll look then up too. ____________________________________________ The front spring bushing one each side is, I think, 55045 20400 about $20 ouch For the shackle there's an A and B side on each one. I've had the 620 apart and they just push in from each side. You'll need two of each if doing both sides. The tops weren't listed but likely the same. If tight to get in use a little vegetable oil not motor oil. Also do not fully tighten the nuts until the vehicle is off the jack stands and sitting on it's wheels. 55046 20400 A about $4 each. 55047 20400 B Thanks for your help. But I tried to order 55046 20400 and 55047 20400 from NISSAN but they do not stock them. Quote Link to comment
datzenmike Posted November 11, 2010 Report Share Posted November 11, 2010 Try asking them if they can check other dealers who may have some old ones in stock just sitting on a shelf. Some will do this others say they will and don't. Quote Link to comment
