Velvetpants57 Posted January 17, 2008 Report Share Posted January 17, 2008 so my 720 4x4 cant go up hills anymore.... its a z22 with a weber 32/36, long tube header, and i think thats it other than stock. it used to climb anything, and go anywhere, but now nothing. So on an 8-10 degree incline thats 100 yards long the truck will make it half way up in second gear and then stumble. the rpms are around 3000 and it just cuts. i dont know if its fuel or spark the engine just goes quiet. then when i let off the gas and put the clutch in it starts to idle again but then shortly there after dies. now on regular driving around town with no hills it does just fine. no stumble no nothing. any ideas guys? Quote Link to comment
V8Dat Posted January 17, 2008 Report Share Posted January 17, 2008 Check the float level. Its actually common for those Webers to brake the floats. One half of it might be unattached. When you set the float level, with the carb top off, you want the fuel to just be starting over the radius where the float bowl curves up by where the needle and seat hang from the carb top. You'll see what I'm talking about when you get it off. Quote Link to comment
Jason Posted January 17, 2008 Report Share Posted January 17, 2008 Check your fuel filter first, I checked it last after messing with everything else and the filter turned out to be partially plugged and only would jam up under load.... Quote Link to comment
DISLEXICDIME Posted January 17, 2008 Report Share Posted January 17, 2008 my webber floats got stuck once i had to tap the top of the carb with a hammer and i was good to go Quote Link to comment
Velvetpants57 Posted January 17, 2008 Author Report Share Posted January 17, 2008 yeah after more investigation and test driving in my neighborhood we decided floats or filter. tomarow i will check. them both. thanks guys i hate working in 11 degree weather. god i hate pullman. (end rant) Quote Link to comment
lancekilgore Posted January 18, 2008 Report Share Posted January 18, 2008 I would to do a compression test on the cylinders then a leak down test. the psi in the cylinders should be 190, if 125 or below you need a rebiuld, according to the book. Lance Quote Link to comment
