60 series 5speed in a B210
SunnyDaze
I have a 60 series 5speed (FS5W60A) and a 120y (B210) coupe. I need a crossmember to install. Anyone have any tips for this conversion?
I've got a B310 crossmember that came with the box that might work with a spacer and some new holes. Did any B210 came out with the 60 series anywhere in the world that I could use the crossmember.
Thanks
  • Replies 2
I ran into the exact same problem. The 5-Speed Rear Mount did not fit my 75 B210, so I used the 4-Speed Mount with 1/2" or 1" spacers to get it closer to the correct height. The 4-Speed had a mount height of 1" but the 5-Speed (FS5W60A) has a mount height of 2".
I am running from memory here and would have to get under the car to check it, but I think the above is accurate. I plan on taking it to a shop and asking someone to make up a bracket that will have the engine at the correct angle.
