DAT510 Posted October 12, 2010 Report Share Posted October 12, 2010 the key you use to open the door is the key used for the ignition right? because the key goes in the ignition but its hard to turn. help? Quote Link to comment
izzo Posted October 12, 2010 Report Share Posted October 12, 2010 normally yes, unless someone has swapped out the ignition at one point, 1 out of 5 datsun keys will open your car and turn it on.. Anyways, try wiggling it around a little bit, put the key all the way in, then slightly pull it out a little and try. If anything else, take it to a locksmith and have them make you a new key to it? Good luck (a super small shot of wd may help too) Quote Link to comment
DAT510 Posted October 12, 2010 Author Report Share Posted October 12, 2010 ill try it later thanks man ill let you know what happens. Quote Link to comment
Cuts metal like mad Posted October 12, 2010 Report Share Posted October 12, 2010 tumbler lube. sold at lock smiths. Quote Link to comment
