tranny cooler
datsunfish
My 71 510 has an auto tranny and apparently when I recently bought a replacement rad I neglected to see if it had tranny line ports.It does not.Rather than track down a 510 radiator with the ports I thought I could use an auxiliary tranny cooler.
Anybody have any good or bad on these?Would it need its own fan?Anybody want to trade?
The radiator in it was solid when I got it but full of rusty slop.The drain plug had been replaced with a bolt that was seized in place.I tried to remove it and ended up removing the whole bung.I had to hammer in a wood plug to make it home.I soldered in a new one but cant seal it up completely since the area was dented when I first fucked it up.
  • Replies 2
You can pick up tranny oil coolers at auto parts stores. I got one for an old Maxima at GI Joes for ~$50. I got the slightly larger one though.
Just strap it to the front of the radiator. Space it forward a little if you can. That will help airflow. No fan required.
