matwood Posted September 26, 2010 Report Share Posted September 26, 2010 I need the bolts or maybe just a measurement for the bolts that hold the control arms to the crossmember. This is the one that goes through the bushing in the control arm. Thanks a ton, Madison I guess after thinking a while I need some more stuff, too.. I need an 510 L16 Oil pan so I can put this L20B in finally. Link to comment
KELMO Posted September 26, 2010 Report Share Posted September 26, 2010 I'm guessing for the '69? Link to comment
matwood Posted September 26, 2010 Author Report Share Posted September 26, 2010 HA, i guess I should have put that... It's for a 70-73 510. ;) Woops... Link to comment
hang_510 Posted September 27, 2010 Report Share Posted September 27, 2010 still avail NEW from nissan. i may have a spare laying around... :unsure: they have a special taper and are not an off the hardware shelf item i also may have an oil pan, gotta check to see if the pickup is there too... Link to comment
matwood Posted September 27, 2010 Author Report Share Posted September 27, 2010 I just called Nissan this morning and they said that it is no longer a valid part number. Here is the one i tried.... 54436-U0101 Is there another number that I should try? And how much for yours if they don't have them, Hang? Link to comment
hang_510 Posted September 27, 2010 Report Share Posted September 27, 2010 if i have it, a few bux to cover shipping. try lynchberg nissan (riley) & ill look tonite :blink: they still were ~2 years ago... Link to comment
Colbino Posted September 28, 2010 Report Share Posted September 28, 2010 I just ordered mine from nissanparts.cc. They were roughly $24 a bolt! Not sure about the part number. I got it off of http://www.carpartsmanual.com/ Link to comment
matwood Posted September 28, 2010 Author Report Share Posted September 28, 2010 I just called them and they said they were no longer avail through nissan with all three part numbers from carpartsmanual.com :( SUUUCCKKS! When you get yours in, or if you already have them, can you look up the part number you ordered and shoot me a message with the part number you used? I may be able to try again i guess... Link to comment
hang_510 Posted September 28, 2010 Report Share Posted September 28, 2010 i have a single bolt avail. Link to comment
hang_510 Posted September 28, 2010 Report Share Posted September 28, 2010 did you call a dealer w/a parts guy that will loook, and then look some more, at the 50th revised number??? this is the latest # i found 54436-A0800 did you use that? Link to comment
matwood Posted September 28, 2010 Author Report Share Posted September 28, 2010 I called Bruce Titus... is there a dealer that you would recommend over them? :/ Link to comment
matwood Posted September 28, 2010 Author Report Share Posted September 28, 2010 I tried that number and the two others listed on http://www.carpartsmanual.com.... 1 dealer in california had 1 new... maybe ill have to get yours and that one... BAH! Link to comment
hang_510 Posted September 29, 2010 Report Share Posted September 29, 2010 try chico nissan or lynchberg nissan, the parts guys will go out of the way (if you ask nicely) to source it. do you need 2? i can see if my friend in SB has any, but wont be able to check for another 2 weeks or so... Link to comment
Chris#51EPGraham Posted October 3, 2010 Report Share Posted October 3, 2010 I've got a pair of decent used ones w/nuts and both special washers, late style, $40 shipped. Chris at cgr8818021@bluefrog.com Link to comment
