Brian D Posted September 19, 2010 Report Share Posted September 19, 2010 I have pulled my timing chain cover as the source of my oil leak. New gasket on the way, is there any gasket to go on the back side of the timing cover in between the cover and metal washer on the crank shaft pulley bolt?? Quote Link to comment
I'm BLUE Posted September 19, 2010 Report Share Posted September 19, 2010 I don't believe so ! Just the timing cover and front main seal , and that should be it ? ( L-series is the same ) Was it the front main seal or the timing cover that was leaking ? :D Quote Link to comment
