7-TWO-510 Posted September 19, 2010 Report Share Posted September 19, 2010 We just took the rotors off to replace the bearings and the spindle nut was loose taking it off how tight is it supposed to be? Thank you. Quote Link to comment
Brian D Posted September 19, 2010 Report Share Posted September 19, 2010 Tighten it back down with your impact or by hand. Then turn 1/8th of a turn forward to the next slot to insert the cotter pin. Quote Link to comment
datzenmike Posted September 19, 2010 Report Share Posted September 19, 2010 Tighten to 22-25 ft. lbs., turn hub several times to seat the bearing, check the torque is still 25 ft. lbs. and then loosen nut 1/4 turn. Adjust the the castellated nut so that the cotter pin will pass through it and the hole in spindle, bend ends over and install dust cap. Quote Link to comment
7-TWO-510 Posted September 19, 2010 Author Report Share Posted September 19, 2010 alrite did do, thanks for all the feedback:cool: Quote Link to comment
