Loren Posted September 16, 2010 Report Share Posted September 16, 2010 my trans in my '70 Goon went bad Sunday. it won't shift while moving,& always made alot of noise (whining,scraping,&grinding ) I swapped out the original L16/column shift automatic,so I had to have the driveline shortened,just replaced the U-joints,and had to cut a hole for the floor shifter. I need a long tail 5 speed to fit without needing another driveline. I'm on unemployment,so i need it to be cheap. the car was my only driver,so i need it to be fairly local. Thanks-Loren Link to comment
datzenmike Posted September 16, 2010 Report Share Posted September 16, 2010 You should widen your search for an F4W71B 4 speed also of cost is a concern. It will also fit your conversion to 5 speed. The F4W63 4 speeds in the 610s are also long and should fit though the mount won't match yours. A 4 spd would at least get you going and might be free. Link to comment
Loren Posted September 17, 2010 Author Report Share Posted September 17, 2010 thanks Datzenmike, I'll look into that trans also. is that by any chance the Z car 4 speed? I've heard that one will work for my current set up. I'm actually hoping to find a '83 280zx 5 speed. my Goon seems to rev pretty high at freeway speeds (55 - 80 mph ),and I hear that trans has a taller 5th gear. as for the 610 trans,i'll watch for one. hopefully it will come still attached to the WHOLE CAR. I've been looking for a 610 for a few years. I had a '73 180b 4 door back in high school,but sold it. i'd always wanted a 510,& the 610 just wasn't quite fitting that mold back in the '80's. I've regretted selling it ever since. it was one of the best cars I've ever owned. Link to comment
datzenmike Posted September 17, 2010 Report Share Posted September 17, 2010 '73/'74 an up Z car and 620 trucks had the F4W71B long 4 speed. Also the '80 2wd 720 truck. '78-'80 810/ Maxima. The 4 spd was discontinued in the Z car in '79 The '80-'83 280zx (NON TURBO) 5 speeds had the tall overdrive 5th gears. Link to comment
Loren Posted September 17, 2010 Author Report Share Posted September 17, 2010 thanks again for the info! Link to comment
