JeremyH Posted January 4, 2008 Report Share Posted January 4, 2008 I have a datsun 620, australian model it is a j15 engine, i cant find any information in relation to timing/idle speed. Does anyone know anything about them? Thanks, Jeremy. Quote Link to comment
DanielC Posted January 4, 2008 Report Share Posted January 4, 2008 These are numbers that I just pulled out of .... the top of my head. Idle 600-700 rpm, manual transmission. Advance, start at 10 degrees before top dead center. If the engine knocks on hard acceleration, retard the timing some. If the engine seems sluggish, advance the timing a little, 1 or 2 degrees, until it knocks. Retard the timing from there. Once again, these are just wild "butt" guesses, but they should get you started. Quote Link to comment
yello620 Posted January 4, 2008 Report Share Posted January 4, 2008 Those numbers sound pretty good as a starting point ot me also. Remember that it is an old motor and that factory specs would only be a starting point anyways, would need fine tuned from that point. I would be willing to bet that those numbers are darn close to factory specs anyways. Jason Quote Link to comment
Hirns Posted January 26, 2008 Report Share Posted January 26, 2008 8 degree BTDC @ 600RPM. I have the original factory manual. Hirns (Aussie) Quote Link to comment
