deadmonkey Posted September 2, 2010 Author Report Share Posted September 2, 2010 my zipcode is 49056.... I don't really need the driveshaft part, just the bearing. It can be a pain to remove but it will save on shipping if you do. Thanks Pic taken today by pushing on the bearing. It is a bit cracked. I'm not sure if you are ok with that or not. Lemme know. I will have to either buy an impact wrench set or socket to get the end off. Also, looks like one on Ebay for cheap brand new: http://cgi.ebay.com/Nissan-Datsun-620-Ute-1971-80-Driveshaft-Centre-Bearing-/130425570506?pt=AU_Car_Parts_Accessories&hash=item1e5df844ca Link to comment
deadmonkey Posted September 2, 2010 Author Report Share Posted September 2, 2010 Also... I'm selling my Kwik Wire 22 circuit wiring harness if anybody is interested. Just posted it on Ebay. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=300463185633 Link to comment
BenJammin Posted September 3, 2010 Report Share Posted September 3, 2010 OK... so I got all the flooring off and there are like 15 screw holes I didn't see before. Still interested? Dunno... where are the screw holes located in the section? Didn't see them in the pic either. If they are clean (not rusted out) I should be able to spot weld them in. btw, thanks for being up front about everything, including stuff to other buyers. Link to comment
deadmonkey Posted September 3, 2010 Author Report Share Posted September 3, 2010 Dunno... where are the screw holes located in the section? Didn't see them in the pic either. If they are clean (not rusted out) I should be able to spot weld them in. btw, thanks for being up front about everything, including stuff to other buyers. They are about 1/8" holes mostly along the side where the previous owner screwed down the rubber matting that was in it. I have a crappy harbor freight special line feed and I still blow through this thin metal. I'm am a novice welder at best, but it would be posible to weld over the holes I'm sure, but you would need to turn the juice way down. So as long as you have a welder with good control I bet you could weld over them. That or just put screws in from the bottom, cut off the extra and tac it in. Link to comment
Braden Posted September 3, 2010 Report Share Posted September 3, 2010 i still need a quote if ya dont mind, my zip is 42503, thanks alot man :D Link to comment
BenJammin Posted September 3, 2010 Report Share Posted September 3, 2010 They are about 1/8" holes mostly... So as long as you have a welder with good control I bet you could weld over them Yeah, go ahead and send it this way, I'll sic the Millermatic 180 on it! Thanks. Link to comment
deadmonkey Posted September 4, 2010 Author Report Share Posted September 4, 2010 quote me a price and shipping costs for the horns (with hardware) also the front marker lenses (the ones on the valance, the tail light lenses, and both headliner clips that the sun visors clip into. thanks alot man!!! lol, didn't even see your post, sorry man, weird. Don't have the clips for the visors, sorry. You just want the lenses with out the rest of the rest? I'd say $10 for the horn and $10 for the rest (same price with or with out the rest cuz I'd rather you take the lenses with the blinkers because that leaves me a mismatched set). Link to comment
deadmonkey Posted September 4, 2010 Author Report Share Posted September 4, 2010 BTW, I appreciate you all being patient. I won't get till your stuff until Monday since my daily driver just died :( and I work weekends, though I will try. Link to comment
deadmonkey Posted September 4, 2010 Author Report Share Posted September 4, 2010 BTW, I appreciate you all being patient. I won't get till your stuff until Monday since my daily driver just died :( and I work weekends, though I will try. So turns out it was a stuck/clogged fuel pump. Pulled that off and using the one bolted onto the engine instead. Quick roadside fix and all is well. I'll see about getting to you guys in order of posts when I get home from work :) Thanks again. Link to comment
Braden Posted September 6, 2010 Report Share Posted September 6, 2010 lol, didn't even see your post, sorry man, weird. Don't have the clips for the visors, sorry. You just want the lenses with out the rest of the rest? I'd say $10 for the horn and $10 for the rest (same price with or with out the rest cuz I'd rather you take the lenses with the blinkers because that leaves me a mismatched set). so instead of the lenses the whole housing with bulb and all? thnats fine if thats the way you wanna send it, it would give me something to restore. let me know man iand i will get you out a pay pal Link to comment
Chumbai Posted September 6, 2010 Report Share Posted September 6, 2010 Do you know what is the gear ratio for the rear end ( 4.38 or 4.88) and how much? Link to comment
deadmonkey Posted September 6, 2010 Author Report Share Posted September 6, 2010 Do you know what is the gear ratio for the rear end ( 4.38 or 4.88) and how much? Sorry bud, I'm making a trailer out of it after I part everything. And I have no Idea what the gear ratio is :( Link to comment
Suspect Posted September 6, 2010 Report Share Posted September 6, 2010 Pic taken today by pushing on the bearing. It is a bit cracked. I'm not sure if you are ok with that or not. Lemme know. I will have to either buy an impact wrench set or socket to get the end off. Also, looks like one on Ebay for cheap brand new: http://cgi.ebay.com/Nissan-Datsun-620-Ute-1971-80-Driveshaft-Centre-Bearing-/130425570506?pt=AU_Car_Parts_Accessories&hash=item1e5df844ca I'll take it if you can take it apart. I like to have one extra laying around, I drive these ol trucks alot. Link to comment
Braden Posted September 12, 2010 Report Share Posted September 12, 2010 so instead of the lenses the whole housing with bulb and all? thnats fine if thats the way you wanna send it, it would give me something to restore. let me know man iand i will get you out a pay pal you have pm Link to comment
Braden Posted September 12, 2010 Report Share Posted September 12, 2010 20 plus shipping for the horns and all lenses? or all lenses and housings? you said rest of the rest? im not sure i understand, do you mean the taillights with all the side markers too? Link to comment
deadmonkey Posted September 15, 2010 Author Report Share Posted September 15, 2010 20 plus shipping for the horns and all lenses? or all lenses and housings? you said rest of the rest? im not sure i understand, do you mean the taillights with all the side markers too? lol, "rest of the rest"! guess I need to work on those proof reading skills before posting. I think I meant taillights with everything as one unit, no side markers, no bumper stuff. I.E. the entire tail lights; lenses, bulbs, seals, wiring. Unless you wanna save on shipping, because I'll probably just chuck them with out lenses. PM me your addy and I'll reply with price for paypal transfer Link to comment
deadmonkey Posted September 16, 2010 Author Report Share Posted September 16, 2010 20 plus shipping for the horns and all lenses? or all lenses and housings? you said rest of the rest? im not sure i understand, do you mean the taillights with all the side markers too? See PM for total. Shipped! Link to comment
deadmonkey Posted September 16, 2010 Author Report Share Posted September 16, 2010 Yeah, go ahead and send it this way, I'll sic the Millermatic 180 on it! Thanks. I got it cut today, but have not packaged/shipped yet. Soon man soon! Link to comment
deadmonkey Posted September 16, 2010 Author Report Share Posted September 16, 2010 how much for the headlight buckets and how r the rings for the head lights email me juliannwetherspoon@gmail.com also how is the cowl and front valence? See PM for total. Shipped! Link to comment
deadmonkey Posted September 16, 2010 Author Report Share Posted September 16, 2010 Pic taken today by pushing on the bearing. It is a bit cracked. I'm not sure if you are ok with that or not. Lemme know. I will have to either buy an impact wrench set or socket to get the end off. Also, looks like one on Ebay for cheap brand new: http://cgi.ebay.com/Nissan-Datsun-620-Ute-1971-80-Driveshaft-Centre-Bearing-/130425570506?pt=AU_Car_Parts_Accessories&hash=item1e5df844ca I haven't forgot about you... I bought an impact set today so that should come right off. I'll keep you posted. Link to comment
deadmonkey Posted September 19, 2010 Author Report Share Posted September 19, 2010 I got it cut today, but have not packaged/shipped yet. Soon man soon! So I had problems getting that out and then ran out of cutting blades :) She is out today, I will ship Monday or Tuesday at the latest. I will get you a total via PM. Just warning you, it may be a bit more than normal for shipping because of the size. I'll let you know if it is crazy. Link to comment
deadmonkey Posted September 19, 2010 Author Report Share Posted September 19, 2010 I haven't forgot about you... I bought an impact set today so that should come right off. I'll keep you posted. I got that pulled today for ya. yay for new tools! I will PM you with a total and should ship Monday or Tuesday once I have paypal $ Link to comment
deadmonkey Posted September 21, 2010 Author Report Share Posted September 21, 2010 my zipcode is 49056.... I don't really need the driveshaft part, just the bearing. It can be a pain to remove but it will save on shipping if you do. Thanks Suspect buddy... I got it all boxed up but need your address. I'll get you a shipping estimate with the Zip you gave me though. I don't recall if we agreed on a price, But how does $10 plus shipping? Link to comment
deadmonkey Posted September 21, 2010 Author Report Share Posted September 21, 2010 Yeah, go ahead and send it this way, I'll sic the Millermatic 180 on it! Thanks. Getting it boxed up today an I'll have a total for you in PM so you can paypal me :cool: Link to comment
