pickleweasle Posted August 23, 2010 Report Share Posted August 23, 2010 Has anyone ever had a 1 piece driveshaft made for a king cab? Quote Link to comment
pickleweasle Posted August 24, 2010 Author Report Share Posted August 24, 2010 If so what are any pros and cons. Quote Link to comment
kelowg Posted August 24, 2010 Report Share Posted August 24, 2010 if at stock height to about lowered 3 inches, single peice is the best upgrade next to front dics you cna make. the only con might be carrier cross member clearance but u can cut that out most important thing is be sure to measure for it correctly Quote Link to comment
pickleweasle Posted August 26, 2010 Author Report Share Posted August 26, 2010 Yea my truck is alot lower the 3 inchs below factory it sits 4 inches at all 4 corners. but theres no problem with me notching any crossmembers. I will eventually be bagging the truck so would it still be best to keep the 2 peice. Quote Link to comment
fastdadd Posted August 26, 2010 Report Share Posted August 26, 2010 i have it on my kc and if you are at stock it will hit the cross member...if to low it will hit the back of the cab..i had to change my pinon angle to get it to work right been a year and no problems.....check my build tread for pics... http://community.ratsun.net/topic/3388-fastdadd-79-kc-620/page__st__20 Quote Link to comment
pickleweasle Posted August 28, 2010 Author Report Share Posted August 28, 2010 Thanks guys very helpful I think i'm going to go with the one peice less parts less problems! Quote Link to comment
