weber carb
phidius
  • Replies 5
just adjust the mixture screw at the base of the carb .
turn it IN till it start running rough/ turn it OUT till it runs rough then pick the middle.
make sure the accel pump works. everythime you cycle the gas ,yiull see a squirt of gas in the main barrel.
maybe you need to adjust the points and make sure the shaft bushing is not loose , and just do a valve ck and ck intake carb bolts for tightens.( NOT too tight!!)
also see where the choke position is.
If manual this is EZ if eleltric make sure its open all the way when HOT. Choke flap open.
